Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LeapFrog LeapPad Platinum 31565 combina una pantalla multitáctil de 7" de alta resolución con un potente procesador de cuatro núcleos. Es el último modelo de la línea de tabletas de aprendizaje de LeapFrog.
Microphone is muffled but speaker works great
The microphone on my son's LeapPad Platinum won't pick up sound or rather it is extremely muffled. We turned the unit off and back on again and it is still muffled. Any suggestions?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
I returned my leap pad and the replacement device also has the same problem. Very frustrated!
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Use a strong light and a magnifying glass to see whether the voice inlet hole in front of the microphone may be blocked.
If it is (or even if you can’t tell), try using a vacuum cleaner to clear the hole of any blockage.
DO NOT use a pin or probe to try and clear the hole as you may damage the microphone.
Here’s an image which shows the location of the voice inlet hole (and the microphone position in the tablet).
(click on image to enlarge for better viewing).
If doing this doesn’t resolve the problem you may have to open the tablet so that you can access the case from both sides to visually inspect that the voice inlet hole is unobstructed.
If it is blocked then it will be easier to clear without causing any damage to the microphone.
Here’s a link to the ifixit LeapFrog LeapPad Platinum Motherboard Replacement guide. It is useful as it shows how to open the tablet so that access to the voice inlet is possible.
If the voice inlet hole is clear then there may be a problem with the microphone itself.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
dogsrpepl2 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 417
