Saltar al contenido principal
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 795 Ver todo
MacBook flashing question mark folder
I have a flashing question mark folder when I boot my Mac.
I have installed a completely blank and unallocated hard drive. When I hold option down I only find WiFi networks no disks. With internet recovery I receive error -6002F.
Do you need to format the hard drive so I can use my Mac?
I only have a PC to format it with so provide instructions for use with a partition manager in Windows/MS-DOS. I also tried a USB drive with Mac OS-X on it from this guide and it doesn't find it either: How to Create macOS Sierra Bootable USB Installer on Windows 10?
Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Yes! You do need to format the drive using Apples Disk Utility as it needs to be formatted with GUID partition table and a journaled file system partition.
The best way to do this is to leverage your old drive. Connect it to your Mac via external HD case (FireWire or USB) or you can use a SATA to USB adapter cable like this one: Startech 2.5" SATA to USB adapter. When your restart your system press the Option key to gain access to the Startup Manager
Then run the OS installer from your now booting older drive or use it to gain access to the OS installers on the Apple Store if you want something newer.
I would recommend you create a USB OS installer thumb drive as its always handy! How to create a bootable macOS Sierra installer drive
Reference:
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Ended up being almost impossible via windows pc so you need a mac. I just purchased a hard drive with mac os pre installed for 30 buck on ebay. This way I can use the app store to download mac os and their interface to format the drive.
- de
Añadir tu respuesta
Michael Mulliken estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 2,667
