RAM 16GB Upgrade Troubleshooting
I installed a 1TB SSD HB 2.5" and it worked like a charm. Then I installed the 16 GB RAM upgrade and nothing. No beeps, no chime, just a black screen and the fan might be running, hard to tell.
Back to the original 4 GB RAM and starts up like a charm. High Sierra and all else is up to date. Tried running the EFI updater available for my machine and got message that it's not supported by my system.
Took out one of the 2 GB sticks and put in one of the 8 GB sticks. Started right up and system info says it is running 10 GB RAM. Took that 8 out and put in other 8 and same result. Runs great. So the RAM I bought is not bad and my RAM slots both work, but it won't run with both 8 GB sticks.
Anyone encounter this too and if so is there a way to get all 16 GB of RAM to work?
- Model Name: MacBook Pro
- Model Identifier: MacBookPro7,1
- Processor Name: Intel Core 2 Duo
- Processor Speed: 2.66 GHz
- Number of Processors: 1
- Total Number of Cores: 2
- L2 Cache: 3 MB
- Memory: 10 GB
- Bus Speed: 1.07 GHz
- Boot ROM Version: MBP71.003F.B00
- SMC Version (system): 1.62f7
If you need more system info to provide help, don't hesitate to ask.
Es esta una buena pregunta?
7 comentarios
Your systems specs: MacBook Pro 13" 2.66 GHz Core 2 Duo (Mid-2010)
- de Dan
Any luck with this? I have the same exact problem!
- de Chaz
Sadly some systems will only go to 10 GB.
- de Dan
I’m afraid not. After a weeek of trying everything under the sun, I gave up and decided to be happy with 10 GB and a boot up time that is faster by a good 5 minutes.
- de shoppingamc
Exact same problem :(
- de Sebastien CHAPUIS
Mostrar 2 comentarios más
