Why is my samsung dryer not turning on?
My Samsung dryer is not turning on, tried everything even replacing main board.
Es esta una buena pregunta?
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Cause 2
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Switch
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the “click.” If the door switch makes a clicking sound, it is probably not defective. If you don’t hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Fue útil esta respuesta?
This is not helpful. The dryer won't even turn on.........no lights, no nothing. It is like it is dead.
Please verify the model number of the dryer?
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 52
Todo El Tiempo: 47,782
15 comentarios
@wizint what is your dryers complete model number? You checked for power on the outlet first?
- de oldturkey03
Yes power to terminal block
- de G Loy
Dv45h7000ew/a2
- de G Loy
I get nothing when I hit power button, as if no power to unit
- de G Loy
Would the thermal fuse keep the board from powering up?
- de G Loy
Mostrar 10 comentarios más
