Toshiba 32" television gone with black screen everything works fine ex
Toshiba 32" television works all good except the screen went black Is it a fuse .
Thank you
Es esta una buena pregunta?
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
Thank you
'''++Patrick OBrien++''' possibly but you will actually have to open it up and take a look. Before you do that, turn the TV to a station where you know it would have a picture. the dim your room and shine a flashlight at an angle against the screen. See if you can make out shapes, silhouettes etc. If so, it is your backlight that has given out. The possibilities with your TV could be a failed power board, failed, t-con board, failed LED driver or a failed backlight array. So, we will need you to let us know the exact model of your TV and once you open the back post plenty of good images of the boards etc. with your question. that way we can see what you see. Agregar imágenes a una pregunta existente
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 121
Todo El Tiempo: 4,186
