Why is my washer making loud noise?
Why does my washer make a loud noise, shake just before it starts spinning? Once it starts spinning it stops and is fine
Es esta una buena pregunta?
Cause 1
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Cause 2
Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing.
Cause 3
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 4,478
1 comentario
It only does it when it starts to spin, so maybe not bearing?
- de Shelley Bauder Compartir
