Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación y soporte para auriculares de tamaño completo que abarcan todo el oído, también conocidos como auriculares circumaurales.
Audio jack causing problems
Isn’t this head set it is the Turtle Beach Recon 50P headset, this is the closest I could find (not in price).
So pretty much what happened was that I accidentally stepped on the edge of the jack while it was in the controller
and bent it a little.
The audio is ok if you get it in the right position but sometimes I can’t cant hear a thing. It also echos other people in the party and gives them a headache.
Just wondering should I try get it fixed it or buy a new headset. I could probably get an audio jack on amazon for cheap enough.
Only bought it a few months ago so want to get at least some use out of it.
Thanks,
R
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@ps4_ron post some images of your damage so we can see what you see. Use this guide for that Agregar imágenes a una pregunta existente Going by your description, I'd suggest that you replace the jack itself. Make sure that there is no fractured wire etc. Replace the jack the same way you would on a regular headset. Take a look at this guide to see how to replace an audio jack. Should be a simple replacement and keeps your headphones out of the landfill (or your junk drawer;-) and saves you some money as well.
Imagen de Skullcandy Lowrider
Guía
Cómo Reemplazar el Conector de Audio
Dificultad:
Moderado
30 minutes - 1 hour
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Ron estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 133
