Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Preguntas 1041 Ver todo
Microphone not working on calls.
So, I’ve got a customer and they’re proposed this:
“When calling, it’s as if the microphone isn’t connecting because no one can hear me. They can hear me fine if I put it onto loud speaker though”.
Just wondered if there were any ideas on the issue and what needs replacing?
Wasn’t sure if it were top microphone, bottom microphone or a speaker.
Thanks.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You need to test it because what the customer says may not necessarily be exactly what they mean.
I've had many cases where they call the earpiece speaker a microphone.
If microphone or speaker too quiet you clean the filters for them. Personally I find 99% isopropyl alcohol brushing to be the best solution, don't douse them in that of course.
If it's not working you will have to replace the part.
For earpiece not working sometimes it's the front camera ribbon assembly cable being ripped or the earpiece speaker needing replacement.
For quiet earpiece, same thing with cleaning. You will also need to open it to clean the filter on the earpiece itself as well, could also have metals stuck on the earpiece speaker which causes the issue too.
And worst case scenario is the audio chip going bad, that requires tools and experience in microsoldering to do so.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Sam Mileberg estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,001
