Saltar al contenido principal
Nintendo Switch es una videoconsola portátil a la que se puede jugar en el televisor a través de una estación de acoplamiento, o sobre la marcha. Sale a la venta el 3 de marzo de 2017.
Preguntas 714 Ver todo
Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
Es esta una buena pregunta?
Puntuación 8
Agregar un comentario
5 Respuestas
Solución Elegida
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
Fue útil esta respuesta?
Puntuación 7
Try this
Precision Screw Extractor Set
Imagen de Precision Screw Extractor Set
Producto
$24.99
Puntuación 3
Welp.. Y00 is correct you might have presed a lot. Y00 works for me
Puntuación 1
So how was this problem solved? I have the same situation. Please help.
Puntuación 1
1 comentario:
Needle nose pliers is what worked for me
Puntuación 0
Añadir tu respuesta
jonathan ambrose estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 25
Ultimos 30 días: 101
Todo El Tiempo: 32,370
