Saltar al contenido principal
Harley-Davidson Sportster Motorcycles from 1986 to Present.
The motor cycle dies after about 30 seconds
i have a 95 sportster battery is showing 12.5v and a full tank of premium fuel , the bike starts and runs for about 30 sec and dies, i can see the gas spraying but the bike won`t stay running
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
If it is a carburettor than most likely it is the idle circuit. Take a look at your filter, is the fuel running through that OK? You might need to pull your carb and give it a thorough clean.
- de
Agregar un comentario
1 Respuesta
This sounds like a gas issue , has it been sitting up ? I would check carb , It may be gunk up from sitting with gas in it , if this helps you great , if not reply
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
also check fuel flow , it can also be not flowing good , (check for TANK TRASH if flow is not good)
- de
It sat over the winter on a battery tender and had it tuned up before winter, well I took the tank off to paint it which all I dissconnected was the crossover fuel hose that leads from obe side of the tank to the other and the 2 fuel hoses on the petcock I took the petcock off to paint, well when I put it back on the bike and start it, it only runs for about 15-30 seconds I see the fuel spraying in the carb
- de
Añadir tu respuesta
chris clayton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 2,008
