Saltar al contenido principal
Un teléfono inteligente Android de Samsung para el mercado asiático, conocido por muchos números de modelo, lanzado en diciembre de 2014.
Preguntas 117 Ver todo
USB only charges A5 but on Lenovo A6000 it connects PC fine, why?
Hello Guys,
There's this strange thing happening, original USB of A5 is only charging A5 when I connect it with PC, I tried every single trick or solution on the internet starting from MTP ending with rebooting updating drivers on the PC. It works fine with the Lenovo A6000. We just want to transfer files from Mobile to PC.
A5 is my mother's phone, she poured water over the phone by accident and the HOME button is no longer working on it, could that be the reason why USB isn't connecting it with the PC and is only charging the phone when I connect it ?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @tommyboy9933 ,
If the PC is not detecting the phone when you plug it in, then there could be a problem with the USB port in the phone (the data -ve and data +ve connections) or perhaps the USB controller in the phone.
Use a strong light and a magnifying glass to check that the USB port enclosure doesn't have lint etc, trapped in it preventing a good connection to the cable plug. If there is debris in there, use a vacuum cleaner to try and suck it out. If it won't dislodge, use a wooden toothpick to gently pry it out. Do not use a metal pin or probe as you don't want to damage the pins or create electrical problems in the phone.
Also check that all the pins are there and they are not bent etc.
If the port looks OK then as the phone has been water damaged in the past, perhaps the circuitry to which the USB port connects to the USB controller has been affected.
The phone will have to be opened and inspected as to what the problem may be.
Here's a link to the ifixit Samsung Galaxy A5 (2015) Repair guides, which may be of some help.
If the phone is still workable, you may be able to download an app that allows you to transfer files using WiFi, between the phone and PC (if applicable)
Just search online for how to transfer files using WiFi Android to get results.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
TommyBoy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,088
