Won’t hold charge
If my iPod doesn’t hold charge is it the battery or the logic board
Es esta una buena pregunta?
Battery. If it boots with a 10W adapter, then the battery needs replacing. Replacing your battery requires a solder and is very hard, similar to an iPhone 2G.
Fue útil esta respuesta?
Most likely it is the battery that needs to be replaced. If the ipod were damaged in some way then there could be a possibility that the logic board is damaged but the only way to tell would be to replace the battery.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 127
Are you syncing to a Mac or PC?
- de mayer
