Saltar al contenido principal
La Canon PowerShot es una cámara de 5,0 megapíxeles con zoom óptico de 4x.
Preguntas 14 Ver todo
usb pin came loose
In regards to my Canon PowerShot A610. The usb port on my camera has come loose and is floating around in the camera. There are three small screws that house the USB. I am unable to attatch a usb cabel to the camera. Can I fix this by snapping it in or do I need to send it in?
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Canon Powershot A610 Camera Housing Replacement
take a look at this guide for how to remove the outer case on your camera. Once you have done this you may be able to locate the loose part and work out how to reattach it without the need for sending your camera to a repairman...which will probably cost more than the camera is worth!
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
+ Great advice
- de
Or if it can't be fixed using pollytintop's answer,you have to buy a mini USB female end and replace it using the same guide
- de
Añadir tu respuesta
Joey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,241
