Saltar al contenido principal
Guías de reparación y soporte para una variedad de joyas.
Preguntas 3 Ver todo
very hard setting, very clear epoxy glue
Hi all. Can anyone recommend an epoxy glue that I can repair a cracked and chipped agate stone that is set into an expensive ring. I really dont want to have to replace the stone as its an irregular shape so fitting a new stone to the ring will be too hard. I want to try to mask the cracks and missing spaces with a tough but clear glue that wont yellow with age. I anticipate mixing it with acetone to give it additional flow. I found something very expensive stuff but before i go that route Id appreciate seeing if anyone has any recommendations. Araldite was too opaque and yellows I think. Many thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
had a look and can find this but not sure if its what your looking for or not https://www.amazon.com/Epoxy-330-Water-C...
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
Thanks so much for looking. I'm in the uk and they dont ship to uk. will look and see if I can find it on the uk amazon
- de
what about car window chip epoxy
- de
good idea. I wonder if I can get it in small quantities though. Its the shipping that seems to send the cost up. I found the 303 glue but even on uk amazon the postage is 3 times the price of the glue! Thanks for your input
- de
Hi I have great success with UV resin it uses ultraviolet light from a UV torch or even the sun, you can get it on Amazon, hope this helps.
Puntuación 0
Añadir tu respuesta
Cecilia Leete estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 362
