La HP Officejet Pro 8600 Plus se identifica por su número de modelo: N911g. Lanzada en 2011, la impresora se puede identificar por su acabado marrón y su panel de control con pantalla táctil.
Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
Hi @rh001 ,
A bit more detail will help us to help you.
What are you trying to do?
For example are you trying to copy documents by loading them in the ADF or in the paper tray?
If so what is the type of document i.e. what is the paper thickness and size etc?
What make and model is the computer that the printer is connected to if you are wanting to print to the documents that "will not feed"?
- de jayeff
