Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Samsung Galaxy A5 (2016), un smartphone Android lanzado por Samsung Electronics en 2016.
Phone dropped in sea water
I have a Galaxy A5 (2016), previously I had some other phones dropped into seawater,
I just used isopropyl alcohol, but now I ran out of it, so I was wondering if i could just simply submerge it in distilled water without disassembling the whole phone as I don't have access to a heat gun.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Hi @loximity ,
How do you propose that the distilled water is going to displace the sea water etc.?
Some of the sea water may get "stuck" inside the phone as you are not washing it away with distilled water by just submerging it in it, simply trying to dilute it somehow. Also allowing it to dry without all the sea water having been removed still allows for corrosion to occur.
Only sure method is to open it up and dis assemble it. You can then use distilled water to flush away the sea water.
Also whilst the battery is still connected there is still the potential for electrical damage due to the salt water conducting electricity (not the distilled water - it doesn't conduct)
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
See this old thread.
Can I use distilled or deionized water to clean electronics?
I do with @jayeff comment.
You should open up the phone, flush away any salt water residue with distilled water, disconnect the battery, and maybe then bathe it in distilled water until you can get some more alcohol.
Puntuación 2
Añadir tu respuesta
Loximity estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 31
Todo El Tiempo: 6,801
