Saltar al contenido principal
La actualización de marzo de 2015 de la pantalla Retina MacBook Pro de 13" de Apple, modelo A1502, presenta procesadores Intel Core i5 e i7 de quinta generación e introduce el trackpad Force Touch.
Preguntas 1185 Ver todo
Is it bad that my laptop fan comes on everytime I use it?
Within 10 minutes of me using my laptop, the fan comes on. It's not very loud, but I can definitely hear it. The fan doesn't shut off until I have closed the lid to my laptop.
I appreciate your thoughts!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Being usually a quiet machine, although it's normal the fans get started after some usage I see here several options:
  • You use your macbook for fairly demanding tasks
  • You are a person very sensitive to noise and use it mainly in silent environment
  • Some undesired task is started up using consistently a high percentage of your processor.
In case the latter seems to you the best explanation, when fans start you can open Activity monitor you will find in Application/Utility folder. Select from menu to show _all_ processes running and see what's using most CPU.
That will give you a clearer picture on what's happening and might answer your question about fans.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
To add to @arbaman great answer. You might also want to look at what the thermal sensors within your system are doing and how they are effecting the fan. This is a great tool for that: TG Pro
- de
@danj Thanks for adding on further infos and help :)
- de
Añadir tu respuesta
Amanda_S_55 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 162
