Saltar al contenido principal
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
How to collapse piston in rear caliper on 1992 civic
i am trying to push the piston in the caliper in with a c clamp to change the pads. it will not budge. should it push in or am i missing something. both sides are the same. i removed the resevoir lid and even opened the bleeder screw to no results. thanks for any help.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Solución Elegida
It takes a special tool. The piston needs to twist in. You should be able to barrow the tool from AutoZone for a deposet or you can buy 1. From this video I see you can also use a chissel like a screw driver to screw it back in.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
thank you so much. i kept looking at the slots in the piston thinking i was probably supposed to turn it. round 2 coming up.
- de
a automotive file works GREAT you can get them anywhere for like $1.00
Puntuación 0
Añadir tu respuesta
rich estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,190
