Saltar al contenido principal
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 645 Ver todo
How to power on? Cant use power pads or keyboard
I am working on converting my old macbook into a SFF desktop to use for media and I need a way to turn it on without the keyboard. The keyboard is stuffed (It had coke spilled through it), the retention arm is broken to hold the cable in also, I tried soldering on another power button onto the power on pads with a resistor (cant remember what resistance I read somewhere) but it didn't work so I took the button I made off and now there is only 1 power on pad visible the other one is just gone and wont jump start with just a piece of wire like it did before. Does anyone know of another way that I can turn it on? Would a keyboard with a power button work?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Schematics show that pin5 (right to left) shorted to ground on keyboard connector of the logic board should allow you to simulate the on/off keyboard button.
However, on these schematics of A1342 I found some other mistakes before, therefore don't blame me if anything goes wrong =;)
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks, I managed to get it turned on using this :)
- de
No need to access the connector this model has power pads!
There are a few versions of this logic board so your pads maybe vertical but are in the same location. You need to do a momentary short across the pads. I would start there otherwise you'll need a replacement keyboard to replace your damaged one.
Puntuación 2
2 comentarios:
As I said above I only have 1 power on pad as I must of unsoldered the other one by mistake
- de
Depending on which pad you can short the good pad to ground as well thats if the sound pad is the one thats damaged.
- de
Añadir tu respuesta
Dominic estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 152
