Start with tightening the lower chassis screws to see if the issue goes away, since it’s least invasive. That said, it can also be the screws inside the LCD assembly, but the issue is the procedure to tighten those is more invasive, and you need to be careful to avoid damaging the LCD - and watch for tape around the frame that’s used to secure it inside.
In most cases, I’ve also noticed it’s usually caused by the lower chassis screws, so the invasive option is not always needed. Refer to this guide to get to the screws for the hinges. However, if you continue to have issues then it usually is within the LCD assembly. You will need to work slowly if this is needed
If neither of these help, then the hinges are worn out or the plastic back cover has failed. These Chromebooks often use fatigue prone plastic, even on the education certified models. The only difference between a consumer/business one seems to be the included contract unless it’s a little tougher at most.
yes or no becaue this is not good at all
- de Bradon Ragland
can someone please answer this? because i have the same problem, and i would like to know if there's a way to fix it by myself before having to go get it fixed. thank you!
- de kara
