Saltar al contenido principal
El portátil HP 15-AF131DX es un portátil de 15,6 pulgadas con un diseño de plástico resistente y hardware decente. Utiliza el sistema operativo Windows 10 Home.
Preguntas 6 Ver todo
How can I fix a jammed charging port?
Okay I was trying to plug in my earbuds without looking and I shoved it in the charging hole instead of the earbuds one and it wasn’t until my laptop was about to die that I realized the charger wasn’t going in, it can’t even go half ways! I don’t know what I did but it would really help me out if you guys got back to me ASAP
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @rubibean ,
You most probably need to replace the DC-In power connector.
You are fortunate as it is a plug in module, no soldering required.
Here is a link to the PC maintenance and service guide for your laptop, taken from this link
Scroll to p.66 to view the necessary pre-requisite steps and then the procedure to remove the power connector. To install the replacement part, simply reverse the procedures.
Here is the HP part number for the connector, 813945-001
Here is a link to suppliers of the part.
It is not a recommendation to use any of them. It is shown just to give an idea of the cost of the part. There may be other suppliers that suit you better.
Just search online using the part number only in the search box to get results.
Hopefully this is of some help.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Rubi Manzo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 571
