Saltar al contenido principal
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 795 Ver todo
I disconnected my LCD screen when battery was still in. No backlight.
I disconnected my LCD screen on accident without removing the battery. I smelt a burnt fuse smell. When I use my new LCD screen there is no backlight. I checked the fuse with the small dot on it, and it looks intact. Do I need to replace the fuse regardless? Do I need board repair? Any help would be appreciated.
Thank you for your time!
Es esta una buena pregunta?
Puntuación 0
1 comentario
Yes, I can log on to my home screen.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
You'll need to test continuity of the fuse a visual inspection is often not enough.
But lets see if the backlight fuse is blown by using a flashlight shining through the Apple Logo. Are you able to see the desktop icons?
Update (03/13/2018)
Well, you're lucky! The backlight logic is damaged. Hopefully its just the fuse link.
At this point I think you'll need to visit someone who has the needed parts and micro soldering skills.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Yes, I can log onto my homescreen.
- de
Añadir tu respuesta
Daniel Castro estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 44
