Saltar al contenido principal
Modelo A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 o 3.8 GHz Core i5 o 4.2 GHz Core i7 Kaby Lake Procesador (ID iMac18.3) / Retina 5K. Consulta las guías anteriores de iMac Intel 27 "Retina 5K Display (finales de 2014 y 2015) ya que el sistema es muy similar.
Preguntas 293 Ver todo
Any potentail for upgrading GPU cooling?
How is the cooling configured inside the 2017 27" iMac?
Is there a heat-sink on the GPU?
Is there space to attach one if there is not?
Are there any potential options to improve the cooling for any of the core components (i.e; replace thermal compounds with higher performing ones, attach heat-dissipation to GPU/CPU that currently lack any)?
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Lets try this, Install this app: TG Pro it will allow you to see the internal thermal sensors and whats happening with the fan. Once you have it running take a snapshot of the main window when its at a point you are getting concerned of the running temp and paste it here for us to see Agregar imágenes a una pregunta existente.
As far as your direct question your system has two heat sinks one for the CPU and a second of the GPU. Both feed the heat to a fin system for the fan to extract the heat and push it out through the back of the system. I would leave the cooling system alone as it as its quite good, unless you have something show up under TG Pro. Then we can see what actions would be needed then.
The simple steps is to make sure the vents along the bottom and back are not blocked so the system can breathe. Also make sure you've not over taxed the system running processes which are over stressing it.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I will give that a shot and share what I find as soon as I have some results.
However, my question is less aimed at fixing an existing problem as it is in preventing a problem. I use my iMac a great deal for Photoshop/Lightroom and the like; but, I also boot into Windows fairly often to play games.
The impetus for my question is in trying to improve duration for peak performance by reducing thermal throttling (if it ever occurs).
- de
I think 'thermal throttling' occures when the GPU reaches 80°C resulting in lower fps (i did quite some testing now). I would like to improve the cooling capabilities as well and thought of this: The foot/stance of the imac is an external heat sink of some kind. The exhaust is venting the hot air directly onto it. Maybe one could add a fin/heat dissipation thingy with thermal glue to it. Right above the hole for the power cable. Then use a quiet fan.
Not sure hot to measure the success though. I guess a GPU temperature of 77° C with 300 less RPM on the main fan would be an improvement. It'd go from "noisy as !&&*" to "I can live with it".
Puntuación 0
1 comentario:
How about running TG Pro so we have something to work with. The link is in my original answer.
- de
Añadir tu respuesta
Soli Ramsdell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,702
