Saltar al contenido principal
Reparación y soporte para ventiladores de techo
Preguntas 31 Ver todo
My Ceiling fan only make humming sound but not moving, Light works.
Ceiling Fan light is working but fan only making humming sound but not moving? I have changed capacitor, checked pull switch and forward-reverse switch. Don,t know whats the issue here.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Respuesta Más Útil
It can also be a problem with the switch connection make sure all the wires are connected properly and make sure the switch is working 100%
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you. I'll look into that also.
- de
Does it spin easily by hand when off? When on and humming, try and get it spinning by hand. Does it take off and start spinning? If so your capacitor may be bad out of the box (rare but happens) or might be the wrong capacitor. If it doesn't, or doesnt spin freely like it normally does, then the motor might be bad/have bad bearings.
Puntuación 1
3 comentarios:
I have this problem. My fan spins easily by hand. Motor hums and changes when speed is changed but fan will not run. It has been this way for a year. Last year I went outside came back and fan had started working. Just turned it off to dust and it will not run. Still spins easily.
- de
@fredric2 sounds like you need to open it up and check the capacitor. Alot of fan capacitors are square with up to 5 wires.
- de
Thank you. That is what I was thinking. Nice to get a second opinion.
- de
I don’t think it is a switch problem. When I change speeds I can hear the hum change. I took the light kit off to look at the capacitor. I ordered a new capacitor and like magic the fan started working again. I have a new capacitor. Next time it doesn’t start I’ll replace it. Until then ‘if it ain’t broke’.
Thank you for your guidance.
Puntuación 1
1 comentario:
I found my direction switch was the problem. I can switch directions a couple of times and the fan will start working.
- de
Añadir tu respuesta
Vikram Raj estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 48
Todo El Tiempo: 678
