Saltar al contenido principal
Publicado en octubre de 2014
Solder points for wires to speaker
I have a pair of Beats mixr headphones with the aux cable soldered straight to the speaker (don’t know why). A wire from the wider cable and a wire from the aux cable have deattached and I would like to see a tear down to see where to re-solder the wires onto the speaker. I can’t take out the Monster cable (it’s actually a genuine cable), and one ear works. The other ear has another aux port. When I use another aux cable, the ear that doesn’t work with the other cable works, but not the one that worked last time. So I have to use a headphone splitter and plug in both cables for both ears to work. But that’s a pain. How would I re-solder the deattached wires? An image of the disconnected wires is below.
Es esta una buena pregunta?
Puntuación 1
2 comentarios
@dudeperson post some images of where you see the wires disconnected etc. with your question. Use this guide Agregar imágenes a una pregunta existente for that so that we can see what you see.
- de
Alright added a photo.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@dudeperson use a multimeter and see if you have continuity between point 3 and 4. Measure between 1 and 3 and 2 and 3 and make sure that you do not have continuity. If those points are true you can solder the ground wire to point 3 or just solder it above or with the ground wire (green arrows) coming from the input cable.
Fue útil esta respuesta?
Puntuación 4
6 comentarios:
I won't be able to try this until about March 17th.
- de
@dudeperson that is fine. Absolutely no problem Somebody will be here to help you out:-).
- de
I tried it. I edited the photo to what we tried.
- de
Looks like I missed the other wire . Try to connect that to #3 if that does not work connect to bottom of #2 with the green wire.
- de
so this means that this very exact solder points are in both headphones speakers? i took my headphones on a repairman, waited for months and paid less than 50 bucks then the problem still persisted, and then i checked the solder, the one side isnt the same as shown in the pic
- de
Mostrar 1 comentario más
Añadir tu respuesta
Jackson Blade estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,492
