Saltar al contenido principal
¿me podrían conseguir una foto de un portatil de este modelo roto, cuanto más hecho pedazo mejor?
Preguntas 16 Ver todo
My display is gone black. It works when connected to external monitor.
My laptop displays a black screen when switched on. However, there is a display when connected to an external monitor. Is it a display problem entirely? How much is the charge to replace display? There is no external damage to the display screen though.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @mohua ,
With the laptop on and a display showing on the external monitor, shine a torch at an angle close to the laptop screen to check if you can "see" an image at all.
If you can you have a backlight problem.
This could br caused by a faulty backlight power supply from the motherboard, faulty backlight cable (not sure if it is a separate cable or part of the video cable), a faulty lid switch or a faulty LCD panel.
If you cannot detect any image at all (try in a darkened room, as it may be easier to see), then you may have a faulty video cable, faulty video cable connections at either end (motherboard or screen) or a faulty LCD screen.
Here's a link to the service manual for your laptop which may be of some help.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Mohua estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,938
