NEED HELP! Camera will not turn on!
My battery is fully charged, but it will not turn on. Please help me figure out how to solve this issue!
Es esta una buena pregunta?
First check the battery compartment door. There is a micro switch that turns the camera off when you open it. If the battery cover does not press down on the switch, the camera won't go on. Make sure that the battery compartment door covers the batteries so that the micro switch senses that the cover is closed.
Fue útil esta respuesta?
I have tried that and it did not work
having the same problem with my canon rebel, did you ever find a solution
I have the same problem. Is there a solution?
I found that this switch is broken on my camera, so is it possible to disable the battery door switch?
@zea213 Take the camera apart, remove the main board, and put a jumper wire on the board. Seal it with UV-curing resin.
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 37
Todo El Tiempo: 2,204
