Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
The Keurig model K70 is a beverage brewing system for home and commercial use. The Keurig is made by the American company Keurig Green Mountain.
I get a message "prime" what does that mean?
After brewing a couple of cups, I get a message that says "Prime" the machine will not work unless I unplug and re-plug. What do I need to do to keep that from coming up?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
James young it is possible that you get the Prime message because the water does not drain from the reservoir. Your reservoir has a filter in the bottom which may be dirty, or your needles are clogged. there could be debris clogging the needle. Use this guide Como limpiar y abrir una cafetera Keurig to work on that. Let us know what you find after.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
James Young estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 40
Todo El Tiempo: 6,360
