Saltar al contenido principal
La Fujifilm FinePix S1800 se lanzó al público en febrero de 2010. Esta es una cámara portátil de alta resolución con un zoom de 18X, que también puede actuar como una videocámara.
Preguntas 3 Ver todo
help for identify parts
Hi,
I need help for a name for a piece for a Fuji S1600; the piece can be common with S1800;
I drew from memory the piece I needed
exemple: if I need LCD for Fuji S1600, Google offer me
https://www.ebay.com/itm/LCD-Display-Scr...
but nothing for electronic mode dial swich
Thank you so much !
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
this is page were I found the answer
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Hi,
I don't know if this will be a help to you or not.
If the Fuji Finepix S1500 Mode Dial assembly is similar to the one in the Fuji Finepix S1600 then it may be.
Here are some images taken from the Fuji Finepix S1500 service manual showing the Top Cover parts and the electrical parts list for the camera.
(click on images to enlarge for better viewing)
Here is a link to the service manual where the images came from.
To download the file, when the sentence below the Document preview box changes from This file is downloadable free of charge: ...processing... to This file is downloadable free of charge: Get Manual, click on the Get Manual as this is the download link. Be patient, it takes a little while to find the file.
As I am not quite sure which part you mean, hopefully you can identify it and then search online for it using the title of the part or the part number from the manual.
Puntuación 3
1 comentario:
Thanks so much!
I would never have known without service manual.
I search for S1600 service manual but did not find it.
The piece I've been looking for was TOP FPC.
Further, search for TOP FPC unit for Fuji S1600, Google offers me many LCD... but I do not lose hope.
Unfortunately, the only solution seems to be an authorized service where it's a little expensive. For example, the $ 10 LCD screen is a very good price; if i can find this TOP FPC at a good price the problem is solved. Aliexpres, do you trust? I saw there lcd screen identical to mine, but I still have not ordered because I have not found TOP FPC. Hope dies last.
Thank you again
- de
Añadir tu respuesta
st_ion estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 190
