HDD Errors (UDMA CRC Errors)
Hi,
In the SMART Utility log file I noticed that my HHD had a high number of CRC Errors. I replaced the HDD with a new Hitachi Travelstart 500G HDD, and still got the same errors. I also replaced the HDD Cable: same result the errors still occur.
See SMART Utility log file below.
Could there be something wrong with my motherboard?
Am I at risk to loose data?
Regards
Erik.
SMART log file:
partition count: 1
partitions: Macintosh HD,
SMART Support: Supported
Last SMART Error: *not set*
Model Family: *not set*
Model: Hitachi HTS725050A9A364
Serial Number: 101128PCK404GLG2GU4J
Firmware Version: PC4OC70E
Capacity: 500,107,862,016 bytes
ATA Version: 8
ATA Standard: ATA-8-ACS revision 6
Health: Passed
Overall Health: PASSED
Offline Data Status: 0
Self Test Status: 0
Offline Data Collection Time: 645
Data Collection Capabilities: 5B
SMART Capabilities: 3
Error Logging Capabilities: 1
Short Self Test Time: 2
Long Self Test Time: 131
Conveyance Self Test Time: 0
Attribute Log Revision: 16
Attribute Count: 19
Attributes:
ID# ATTRIBUTE NAME FLAG VALUE WORST THRESH TYPE UPDATED FAILED RAW VALUE
1 Raw Read Error Rate 0x000B 100 100 062 Pre-fail Always Never 0
2 Throughput Performance 0x0005 100 100 040 Pre-fail Offline Never 0
3 Spin Up Time 0x0007 173 173 033 Pre-fail Always Never 2
4 Start/Stop Count 0x0012 100 100 000 Old age Always Never 136
5 Reallocated Sector Count 0x0033 100 100 005 Pre-fail Always Never 0
7 Seek Error Rate 0x000B 100 100 067 Pre-fail Always Never 0
8 Seek Time Performance 0x0005 100 100 040 Pre-fail Offline Never 0
9 Power On Hours 0x0012 100 100 000 Old age Always Never 75
10 Spin Retry Count 0x0013 100 100 060 Pre-fail Always Never 0
12 Power Cycle Count 0x0032 100 100 000 Old age Always Never 73
191 G-Sense Error Rate 0x000A 100 100 000 Old age Always Never 0
192 Power Off Retract Count 0x0032 100 100 000 Old age Always Never 1
193 Load Cycle Count 0x0012 099 099 000 Old age Always Never 13221
194 Temperature Celsius 0x0002 229 229 000 Old age Always Never 24 (Lifetime Min/Max 15/39)
196 Reallocated Event Count 0x0032 100 100 000 Old age Always Never 0
197 Current Pending Sector Count 0x0022 100 100 000 Old age Always Never 0
198 Offline Uncorrectable Sector Count 0x0008 100 100 000 Old age Offline Never 0
199 UDMA CRC Error Count 0x000A 200 200 000 Old age Always Never 143
223 Load Retry Count 0x000A 100 100 000 Old age Always Never 0
Error Log Version: 1
Error Count: 75
Error Log:
Error 75 occured at disk power-on lifetime: 75 hours
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
00 51 01 10 00 00 00
Error: Unknown
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
2F 00 01 10 00 00 00 00 00:13:12.500 READ LOG EXT
60 00 30 88 40 67 40 00 00:13:12.500 READ FPDMA QUEUED
60 E8 28 F0 D5 66 40 00 00:13:12.500 READ FPDMA QUEUED
60 10 20 E0 D5 66 40 00 00:13:12.500 READ FPDMA QUEUED
60 08 18 D8 D5 66 40 00 00:13:12.500 READ FPDMA QUEUED
Error 74 occured at disk power-on lifetime: 74 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:01:32.500 READ LOG EXT
60 B8 F8 68 1B 93 40 00 00:01:32.500 READ FPDMA QUEUED
60 00 F0 68 13 93 40 00 00:01:32.500 READ FPDMA QUEUED
60 00 E8 68 0B 93 40 00 00:01:32.500 READ FPDMA QUEUED
60 00 E0 68 03 93 40 00 00:01:32.400 READ FPDMA QUEUED
Error 73 occured at disk power-on lifetime: 70 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:37:53.600 READ LOG EXT
60 50 B8 08 55 54 40 00 00:37:53.500 READ FPDMA QUEUED
60 A8 B0 58 4F 54 40 00 00:37:53.500 READ FPDMA QUEUED
60 00 A8 58 47 54 40 00 00:37:53.500 READ FPDMA QUEUED
60 78 A0 E0 41 54 40 00 00:37:53.500 READ FPDMA QUEUED
Error 72 occured at disk power-on lifetime: 69 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:52:46.300 READ LOG EXT
60 00 30 A8 79 BD 40 00 00:52:46.200 READ FPDMA QUEUED
60 00 28 A8 77 BD 40 00 00:52:46.200 READ FPDMA QUEUED
60 00 20 A8 76 BD 40 00 00:52:46.200 READ FPDMA QUEUED
60 80 18 28 76 BD 40 00 00:52:46.200 READ FPDMA QUEUED
Error 71 occured at disk power-on lifetime: 68 hours
Error: Unknown
2F 00 01 10 00 00 00 00 00:36:21.200 READ LOG EXT
60 40 F0 28 B6 B0 40 00 00:36:21.200 READ FPDMA QUEUED
60 40 E8 E8 B5 B0 40 00 00:36:21.200 READ FPDMA QUEUED
60 40 E0 A8 B5 B0 40 00 00:36:21.200 READ FPDMA QUEUED
60 40 D8 68 14 B0 40 00 00:36:21.200 READ FPDMA QUEUED
Self Test Log Revision: 1
Self Test Log Count: 2
Self Test Log:
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
- 1 Extended offline Completed without error 0% 74 -
- 2 Short offline Completed without error 0% 11 -
Es esta una buena pregunta?
