Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Preguntas 1041 Ver todo
Black screen but still on
So I recently bought an iPhone 6s plus screen and I've hooked everything up myself it wasn't my first time either. As I began charging it the battery logo shows and when it turns on the phone is pitch black I still can get notifications but can't see anything. There are times that the screen will flick on then quickly off. So the only thing I can see on the phone is the battery/charging screen. No apple logo or anything.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Probably a defective screen, if the old screen still works, hook that one up and see if it displays properly on there.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
thanks and yes i tried that didn't work either.
- de
Check the backlight capacitors above the screens flex cables connector (on motherboard) , seen many 6s plus with bad ones there.
But on that model there is two backlights (one for left and one for right side) so should work if not both is bad. Still worth to check
Puntuación 2
3 comentarios:
Everything seems fine there. However, I'm not sure what I'm supposed to be checking for.
- de
Do you have a multimeter?
- de
nope I don't.
- de
Añadir tu respuesta
Juston estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 116
