Saltar al contenido principal
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 794 Ver todo
Software for transferring data between replacing hard drives
I am going to put in a new hard drive but i do not know how to get the info for my old hard drive to the new one. I thought i might have seen it on the sight but now i cant seem to find it. When i transfer the data will all my downloaded applications go with it thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You'll need a external hard drive adapter or enclosure to hook the new drive up to and format it, then use SuperDuper to clone it>http://www.shirt-pocket.com/SuperDuper/S...
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
when you say a external hard drive adapter, a external hard drive? and then copy the current drive in my computer to the the external one using SuperDuper then instal the new hard drive and the sync superduper?
- de
You have to have a way to talk to the new hard drive and at the same time use the current drive. This can be done by using a adapter such as this one: http://eshop.macsales.com/item/Newer%20T...
or an external enclosure to put the new drive in, such as this one: [producto vinculado inexistente o deshabilitado: IF107-097]
If you use a firewire drive you can also boot from it.
- de
Añadir tu respuesta
eweirick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,029
