Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación, desmontaje e información de resolución de problemas para el iPad de Apple de 4ª generación con red celular 4G LTE GSM (AT&T), disponible con 16, 32, 64 o 128 GB de almacenamiento. Lanzado en noviembre de 2012. Identificado por el número de modelo A1459.
New digitizer not functioning?
Had a particularly frustrating screen replacement yesterday with a digitizer screen that fracture and splintered with every successive pry. Finally managed to get everything apart and cleaned up with no further damage to internal components (VERY surprised that the instructions did not specifically call out disconnecting the battery BTW). Reassembled everything and went to test prior to sealing the new screen down only to find that it's not functioning. The home button works fine and the LCD has crystal clear picture, but there's no touch input whatsoever. Any chance we got a bad digitizer? Recommendations?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Final follow-up on this. The original digitizer was sent back before I could retest it, but I had the exact same issue on the replacement. I found that the white lines on the digitizer cable need to be inserted further into the connector (until they disappear into the connector). Unlike the LCD screen connector where the lines are still showing.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Probably just a bad digitizer, you did fully insert the digitizer ribbon cable into the port and clipped the two connectors down right?
The battery does not need to be disconnected for digitizer replacements on iPad 2, 3 and 4 because the LCD does not need to be unplugged during a digitizer replacement, it simply just needs to be moved out of the way.
Note to others, always test the touch screen and home button before fully installing the digitizer as you may just crack the glass when removing it again.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Eric Montgomery estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 338
