screen only lights up for a few seconds
screen lights up very dimly for a second, can't read anything on it. Incoming calls work but can't make outgoing calls or access any info contained on the phone. Do I need a new power pack? I see it is possible to buy one from Duracell.
Es esta una buena pregunta?
Puntuación
0
Hi,
What happens when you connect the charger to the phone?
Do you get a charging indication on the phone?
Try using the phone with the charger connected and switched on.
- de jayeff
Unfortunately nothing, no charger indication and can't use phone with charger connected and switched on.
- de Elaine Matthews
Hi,
You could try a new battery as they aren't that expensive. At least it will prove whether or not the battery is the cause of the problem
- de jayeff
I will probably do that, thanks
Decided to buy another phone cheaper option but thanks for help
