Why is my laptop the way it is.?
When turned on it is all black with white letters saying "System not found n more.
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 121
Hi @alizew1013 ,
It may be that the hard drive (HDD) has failed or has become corrupted.
Try entering BIOS when you start the laptop (should be a message on the screen soon after you turn it on to either press either F2 or Del -not quite sure which - to enter BIOS) and see if the there is an entry for the HDD listed under drives.
What OS is installed in the laptop?
- de jayeff
Go into the bios
Check an option labeled "EFI", see if it is on or off. If it is on, turn it off. If it is off, then turn it on. Save changes exit the BIOS and restart the computer.
- de S W
