HP Pavilion 15n-288uc / 5CD40512TN: install a wifi Bluetooth Chip Car
Can I install a wifi Bluetooth Chip Card in this Pavillion...
Where can I find a Technical Manual?
Es esta una buena pregunta?
Hi,
Here is a link to the service manual for your laptop.
Scroll to p.51 to view the necessary pre-requisite steps and then the procedure to remove/replace the WLAN module.
Also on p.51 you will find the part numbers for the various WiFi modules that are suitable for use in the laptop dependent on their configuration. If you search online using the appropriate part number only you will get results for suppliers of the part.
Hopefully this is of some help.
Fue útil esta respuesta?
Yes, you could put one in. The laptop does have a mini PCI socket and this ifixit guide, HP Pavillion dm4t-2100 Touchpad Replacement goes deep enough into the computer to replace the card. Just follow the guide to step seven and the rest is pretty much self explanatory. Good Luck!
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 108
