My power brick is lighting up orange but my Xbox won't turn on
I try to turn on my Xbox and the power brick is lighting up orange but the Xbox won't turn on period..It's not lighting up or anything but when you press the button to turn on you can still hear the sound it makes when your trying to turn it on..
Es esta una buena pregunta?
6 comentarios
My symptoms are slightly different, as I hear / see / smell NOTHING when I attempt to power on my XB1 original, using a known good power supply. Other units I have repaired in the past exhibited these symptoms when the power button ribbon cable inside the top cover was disconnected. After checking this unit, however, the cable was correctly installed. Any thoughts?
- de jtheires
I have this exact problem, has anyone found a fix?
- de Wreave 01
I have the same problems it sounds like it wants to start up but gives up after a second I've tried everything
- de Christopher Richardson Sr
I have this same problem as well.
When I plug in the original power supply into the wall outlet, but not the Xbox, the light on the power supply remains a constant yellow/orange tint.
When the original power supply is then plugged into the Xbox, the light immediately goes away within 1 second.
I then bought a non-OEM power supply off of Amazon - YCCSKY (thinking this would be the fix).
When this power supply is plugged into the wall, but not the Xbox, the light also remains a constant yellow/orange tint.
When this power supply is then plugged into the Xbox, the yellow/orange light begins flashing.
With the original power supply plugged in fully (wall outlet and Xbox) and no light on, I get no sounds from the Xbox at all when pressing the power button or the eject button.
With the non-OEM power supply plugged in fully (wall outlet and Xbox) and a flashing light, I can at least get very faint sounds from the power button and the eject button, but still nothing happens.
- de DGAF0752
Brawl my Xbox won't turn on even though that the power is working fine and my break is lighting up orange and the Xbox makes the Xbox sound like when you turn it on but it doesn't seem to turn on
- de LLOYD TERRY
Mostrar 1 comentario más
