Saltar al contenido principal
Lápiz óptico de primera generación de Apple para el iPad Pro, anunciado el 9 de septiembre y lanzado a mediados de noviembre de 2015. Modelo A1603.
Transplantation of the Apple Pencil innards possible?
I read the Pencil teardown and understand that the outer plastic and inner metal shell needs to be destroyed. Are the electronic components still working after this procedure? Is the metal shell essential or is it a safety measure in case the battery decides to expand/explode?
Just food for thought: I have a 3d printer and wonder when the battery dies by age and usage if it is possible to either print or misuse a real ergonomic pen casing to transplant the electronic innards and additionally exchange the battery circuit to a swappable 3,7v ±5% AAAA sized battery and maybe add a on-off switch. Not sure if the lightning/bt pairing will be lost once you unpower the logic board, as apple designed the pencil to be permanently on/hibernation.
I know it may not be worth the hassle and newer and better revisions of the pencil will surely appear by the time the internal battery dies, but I am a bored engineer.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
I’ve no solution for you but I love the idea and approach.
Get boredome to use. Have a good repairing day
Fue útil esta respuesta?
Puntuación 0
Hello, i have the same project. You solved my problem finding a battery! Thanks. I bougth a 10USD used apple pencil w/dead battery to try it.
Puntuación 0
Añadir tu respuesta
DGX estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 1,008
