HDD physical dimensions for replacement
What are the dimensions of the HDD? I want to replace mine with a 5 TB 2.5" drive but I'm not sure if it will fit as it has 15 mm of thickness instead of the usual 7 mm
Es esta una buena pregunta?
I dont have the exact dimensions for you but these are sometimes available on amazon under the part specs. However I would suggest going faster than larger. I would try a hybrid drive for storage space and speed unless you can afford a large ssd drive.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 317
