Saltar al contenido principal
Does not turn on, red light blinks 5 times!
Ok so my Samsung UN40H6203AFXZA tv will not turn on and that red light at the bottom just blinks (5 times). I have changed the power board and main board. Please any ideas will help!!! What about the T CON board?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
try holding volume down(-) on TV and power on remote
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@jmbucknertx check the fuses on your T-con board. make sure they have continuity. If not replace the fuses. Post some pictures of your T-con board with your question so we can see what you see. Use this guide Agregar imágenes a una pregunta existente for that.
It is possible that this is your -con board but there is also the possibility that this is caused by bad LED arrays.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
I have a Samsung smart tv I have replace all the board,but still do not any video, I have sound any ideas?
FBT
- de
Fordyce B. Townes II what model is your TV and what have you checked? you've made sure to try all your inputs with different sources like DVD, Component, Coax, HDMI etc.?
- de
Having same trouble. I first suspect the main board has taken a hit from frequent lightning in our area. This happens often coming in through our cable TV box.
I am hoping there was a resolution to the posters problem. Knowing it could help me. In the mean while I will be checking as much as I can (transistors, caps, fuses, resistors) using my digital Multi meter.
- de
frequent lightning in our area ? be sure all services (cable, satellite, phone, electrical, etc.) use the same ground rod at your place - that will help keep it to a minimum
Puntuación 0
Añadir tu respuesta
Justin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 55
Todo El Tiempo: 16,668
