Saltar al contenido principal
Mando PS4 modelo CUH-ZCT1. Lanzado en noviembre de 2013 por Sony Computer Entertainment, este controlador de batería de iones de litio de 3,7 V y seis ejes no es complicado de reparar. (NOTA: la guía de desmontaje NO es para este modelo)
Preguntas 388 Ver todo
Controller wont charge or power on
I'm trying to fix my friends Dualshock 4 but I can't seem to figure out the issue. I've never tried to fix a Dualschock controller so I could just be missing something.
The controller will not charge at all (light bar wont turn on either). I have replaced the battery and the USB charging port alongside with the ribbon that connects the port to the board. Nothing happened when I replaced the battery, but after replacing the USB port I noticed that the controller circuit board was getting hotter when I had the USB plugged in. Although, the controller still wont charge or turn on.
I was just wondering if anybody had any suggestions on what the issue and fix could be.
Thanks,
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Hi Trevor,
This troubleshooting wiki might give you some suggestions on what else to try. It looks like replacing the USB charging port is a last-resort thing to try, and it sounds like it may have made things more complicated for you.
As always, good luck!
Fue útil esta respuesta?
Puntuación 0
Maybe you have the same issue is my controller where the Touchpad makes the controller unusable? And disconnect the Touchpad makes it work again.
DualShock 4 seams death when Touchpad is connected
Puntuación 0
Ive replaced the battery, ribbon and charging port. The controller flashes and shows it's charging. But it DOES NOT CHARGE.
FRUSTRATING ARRRRRGH. !!
Puntuación 0
Añadir tu respuesta
Trevor Corbin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 7,657
