Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La instalación eléctrica en los Estados Unidos se refiere al proceso de instalación de sistemas eléctricos en edificios y estructuras de conformidad con las regulaciones establecidas por el Código Eléctrico Nacional (NEC) y los códigos de construcción locales.
Replacement Timer for Intermatic Landscape Light Transformer
Would like to repair this unit rather than replace it. The timer mechanism has worn out and will not turn on the transformer when the tripper reaches the set time. It stalls at the set time and apparently slips when the tripper engages the switch. The part tag shows the timer as Intermatic PB115M2 but internet search shows no results. Any ideas? Thanks!
Es esta una buena pregunta?
Puntuación 0
3 comentarios
As a followup to this issue. I was unable to find the timer mechanism but was able to replace the light sensors in my two boxes. The light sensors are still manufactured by Intermatic (Intermatic K4021C 120-Volt Fixed Position Thermal Photocontrol) and the system now works fine as a dark to daylight controller. Not completely fixed.... but functional and not in the Landfill.
- de
I have the same problem too. I dont want to spend another $200 for new transformer just because of the timer..
- de
I have the same problem too. don't spend extra for new transformer just because of the timer..
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Hi,
If it plugs into a power outlet and you can leave it set permanently to ON then the easiest way to continue to use it, as finding the correct replacement timing mechanism may be difficult, is to connect it via a timer to the power outlet. (The timer is just an example, you may find a cheaper one that suits you better).
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
Jayeff, Good idea!,
I have to find a way to protect an additional timer from the elements as the original plugs into a weather protected outlet.
- de
Hi Steve,
More expensive but here - https://www.bunnings.com.au/hpm-24-hour-... again just an example as you are 120V and this is 240V but the idea is the same
- de
Timer conected to timer? Lol
- de
I am new here. I found this thread when I was searching for a solution of a light transformer related problem.
- de
ML121RT, timer quit working. Tried to find replacement timer. Could not find the exact timer. I found ordered and installed a WG2030 timer motor from Ebay. It’s working and keeping time. $23 Free Shipping.
Puntuación 0
Replacing the timer might be the best bet. While we couldn't find that specific part, HPM makes high-quality timers: Total Tools HPM. Check their selection to see if a compatible option is available.
Puntuación 0
Añadir tu respuesta
Steve Mattson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 119
Todo El Tiempo: 9,686
