Saltar al contenido principal
The Panasonic KX-E603 electronic typewriter is a semi-computerized typewriter produced between 1984-1989.
Preguntas 4 Ver todo
Can I adjust the paper roller on my Panasonic KX-E603?
I inherited a Panasonic KX-E603 and use it in my child care. Lately the paper roller seems loose and won't roll in new paper. Is there a way to adjust the roller?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Here is a link to the ifixit Panasonic KX-E603 Stepper Motor Replacement guide.
It is useful because at Step 6. in the procedure it mentions roller wheel adjustment knobs. Perhaps you can adjust the roller wheel tension by use of the knobs.
Hopefully this is of some help.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
I ended up taking the roller out and found 2 plates each having two smaller rollers (to assist with rolling the paper in and out). one of the side supports had broken for the left plate. I stuck in a piece of a coffee stirrer to support where the support was missing. Put it all back together and working just fine now! I will save your info for future reference!! Thank you!
- de
Hi Dawn,
Good fix!
Hopefully the "coffee stirrer piece" (and the glue?) will go the distance.
If you haven't already found it here is a link to all the ifixit repair guides for your typewriter
- de
Añadir tu respuesta
Dawn Stonehocker estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 176
