apple hi-fi won't work on mains, it only works on batteries.
Hi, my apple hi-fi won't work on mains supply, it only works on batteries. help
Es esta una buena pregunta?
Hi @iain_sinclair ,
You will have to open the device and then check the connections from the mains power inlet to the motherboard.
Here is a link that hopefully may be of some help.
If you cannot see (or test, using a DMM- digital multimeter) what the problem is, take some close up pictures of the motherboard and perhaps someone will be able to help you further. Here's how to do that. Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 162
Please explain. Do you mean it won't work on wall power?
- de Reed Crosby
yes, thats correct it won't work on wall power
- de Iain Sinclair
Have you tried a different outlet?
- de Aiden
yes tried different wall outlets and different power lead, the problem is with the apple unit.
- de Iain Sinclair
did you drop it before? anything happen before it broke?
- de Aiden
Mostrar 2 comentarios más
