Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 1049 Ver todo
top right corner heats up while screen is on with screen problems
During normal usage my iphone SE's screen is having some grey lines over the texts all of a sudden and the front of the top right corner heats up badly within 10 seconds the screen is on, then the touch screen isn't quite responding, sometimes there are even some stripes.
I read that the screen problem might be fixed by detaching the cable, cleaning it a bit and reconnecting it (correct me if i am wrong), but I am more worried on the heating up part.
Anyone has an idea on this whole problem i am having? Thank you in advance.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The top right corner is right where all the connectors plug to the logic board. If your iPhone has never been previously opened, from your description I would suspect some faulty component in that area. In case it's been repaired earlier some connector might have been misplaced.
One way or the other overheating points to a short to ground which has to be taken care at the earliest.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
SPEZ estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 287
