Saltar al contenido principal
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
Preguntas 526 Ver todo
Must I change the screen of my mobile?
the screen appear with changeable color after reaching water to it
some water reaches to my mobile ,I didn't know and I connect it to recharge but it did not recharge. After removing battery I found some water , so I cleaned it with pure tissue and it worked normally for few minutes then turned off and give changable colors with normal feature (app , time. date , ....etc) and the touch didn't work
Must I change the screen of the mobile((((( S4 I9515))))
Es esta una buena pregunta?
Puntuación 0
2 comentarios
now the mobile give more colors and the touch do not work so do this mean I must change the display ?
- de
Hi @phahmed ,
Have you cleaned the entire phone as per the answer below, including disconnecting the display cable from the systemboard connector and cleaning the connector socket and the cable connectors as well?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @phahmed ,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
Electronics Water Damage
You may have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone which may be of some help.
Samsung Galaxy S4
If this process seems too daunting, take your phone to a reputable, professional phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Fue útil esta respuesta?
Puntuación 5
Añadir tu respuesta
ahmed estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 68
