Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
Guías de reparación, desmontaje e información de resolución de problemas para el iPad de Apple de 4ª generación con red celular 4G LTE GSM (AT&T), disponible con 16, 32, 64 o 128 GB de almacenamiento. Lanzado en noviembre de 2012. Identificado por el número de modelo A1459.
Ipad 4 not charging and not starting
Dear tech-people,
my Ipad 4's battery has reached 0% two days ago. As usual I attached it to the original charger (with non-original cable) but it would neither charge anything (just stay as in the attached picture) or boot. After inserting the cable and after pressing the power button the attached picture appears on the screen for two seconds but nothing else. It stayed on the charger for around 24h now without any changes.
I have already researched a little and have tried a second cable, charging dock and cleaned the lighting adapter (nothing noticable came out). I also tried the different combinations of pressing the power and home button, but the Ipad would just stay in the state as in the picture.
I have run over this tutorial from 2012: Ipad Dock connector no longer working
Does anyone know if this procedure would be applicable to the Ipad 4 too? Any other ideas?
Thank you a lot for your help!
Best regards
SadIpadUser
Imagen
Es esta una buena pregunta?
Puntuación 1
1 comentario
Did you try the actual Charging block that the charging cable pluygs into. Sometimes those can go bad. .. If so I would try another charge port inside the ipad itself. Its showing that it reads it was connected , but not actually charging so If you already tried a replacement. I would try a second before rolling it out. Last thing I would try is a battery. If none of this works, then it's possible something on the logic board shorted out.
- de Compartir
Agregar un comentario
2 Respuestas
Solución Elegida
Anyway OP here is a link on how to replace the charging port:
Sustitución del conector Lightning del iPad 4 GSM
And here is link on where to buy the replacement part:
iPad 4 Lightning Connector
Imagen de Replace a lightning connector compatible with the 4th Generation iPad Retina model A1458, A1459, and A1460. Fix problems with charging and data transfer.
Producto
$19.99
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
Thank you for your help,
I will order the lightning connector and try to replace it.
Is it necassary to buy the microwave heat thing or can I also use a hairdryer for that? Thanks again
- de Compartir
Hair dryer will do. I personally would use a heat gun at 120°C but I open these without heat anyway as I'm used to doing it.
Hair Dryer is about 60-70°C on high but will do the job, it'll just take a bit longer to soften and heat up the adhesive.
- de Compartir
That image shows that the ipad didn't recognized the cable and that's why is not charging. If it would charge fine you should see only the battery without the cable and eventually to turn on. The problem can be from the cable ( but you already tried that), the charging port inside the ipad that need to be changed (you need to take the glass off to do that) or is a logic board issue.
Puntuación 1
2 comentarios:
To be honest for a person that repairs iPads regularly it's pretty easy to take off the glass without cracking it.
Luckily this charging port is fairly easy to remove once the screen is taken off as it's just a plug in modular part and is held in by a few screws.
- de Compartir
Thank you for your help, I will try your tips in that order.
- de Compartir
Añadir tu respuesta
SadIpadUser estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 44
Todo El Tiempo: 3,547
