Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2,2 GHz (Turbo Boost de hasta 3,4 GHz) o 2,5 GHz (Turbo Boost de hasta 3,7 GHz) con 6 MB de caché L3 compartida.
Preguntas 467 Ver todo
Changed screen and now have only white screen when turn on computer
I changed the display screen with new one, turned on and get a white screen? checked all connections, even plugged in broken screen and it still lit up on part of glass not cracked. any ideas?
Es esta una buena pregunta?
Puntuación 1
2 comentarios
What happened with the previous screen to need a replacement ?
- de
Daughter dropped off desk and cracked the screen, ultimately had to send to Apple and was fixed
- de
Agregar un comentario
3 Respuestas
Solución Elegida
The original screen had a small crack after falling off a desk and the bottom half of the screen was not working. Ordered a replacement screen and the replacement screen was faulty.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
surely this is a software problem. Try starting up from an external USB device with a known good system on it. If it boots, run Disk Utilities from the external drive and see if that will do the trick.
Puntuación 2
Maybe you have not connected all the wires. If it is not of this then you will need programming pairing which only Apple does, and because you replaced the screen yourself they may not do it because it is Apple .
Puntuación -1
2 comentarios:
Never heard of that before. There is no programming a screen.
- de
I like to see some validation of this programming pairing. Could you give us a link?
- de
Añadir tu respuesta
herrky estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 201
