How much is it to fixed my screen
My screen is shattered how much would it cost to get it fixed
Es esta una buena pregunta?
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
If you wanted to repair the phone your self, the display assembly is around $30-35 USD.
It would likely be $20-$40 labor for a shop to do it.
Comentarios:
My phone cracked up
- de Javez Moore
It's easy to change the screen. Buy the screen and I'll change the screen for u for free.
- de CHiNOSKiEEZ LOKEZ
Can you walk someone thru the repair via webchat?
- de jerilyncov
How much is zte phone screen model Z982
- de abiola david
Buy oem screen on eBay 28 bux, prolly 20 labor from "pro..." Or YouTube that ish yourself.
My whole screen is cracked on my ZTE blaze how much would it be to fix the screen will it be over 100 or under if I had to take it somewhere to get it fixed
Comentarios:
my zte 2 blade max cell phone work charger and not work powern off/on you will fix what wrong what kind find my cell phone
- de mrjoker1965
They are many places where you can get a display dependent on your location. See the guide below.
My ZTE zmaxx pro blade my screen is crack on the right hand side how much will it cost me
Comentarios:
That's the same price, when you replace the screen, all the front panel of the phone come with it...
- de sl0wM0_44
My zte is cracked on the the bottom left and right and top right and a little cracked in the middle how much would that be to fix the whole screen
Rep: 1
My zte is cracked all over and it want come back on PERIOD POOH!!!
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 54
Todo El Tiempo: 14,008
How much is it to get my screen fixed on my zte max pro
- de Kattie Sanders
My phone screen the glass part is shattered from the top left corner. How much would it cost to fix the screen?
- de Iva Stewart
How much is it to fix my screen zte max pro
- de rhondasutton71
how must do it cast to get my phone screen fix
- de Nystasia Scott
How my will my zte phonecist to fix the screen
- de Kaylen Upton
Mostrar 9 comentarios más
