Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Pantalla LCD panorámica de 4,3" con un procesador de 333 MHz. Número de modelo PSP98510. La reparación de este dispositivo requiere destornilladores comunes y herramientas de palanca.
PSP black screen, green light on and orange light blinkinv
Hi, I think the title says most of it. The screen lights up but there's no image, green light is always on and on the left 1st orange light is blinking.
I already tried holding HOME + L1 button, no reaction. Tried SELECT + START + TRIANGLE + SQUARE, PSP just turns on but no image.
Is there any way to fix it without pandora battery and magic memory stick?
Es esta una buena pregunta?
Puntuación 1
4 comentarios
Try removing your memory stick perhaps? The flashing orange light means that the PSP is accessing it, it could however be corrupted returning an error...
- de
I have tried that several times. Tried, taking the memory card out, turn off the psp then take out sd card, and did many other make-believe solutions but all result to the same issue that I have
- de
@alexniculescu i tried it didnt work ;-;
- de
Hold all 5: HOME+SELECT+START+SQUARE+TRIANGLE and POWER IT UP.
- de
Agregar un comentario
6 Respuestas
Solución Elegida
The problem was the memory card. I took it out and now PSP works.
Fue útil esta respuesta?
Puntuación 4
Try taking the battery pack out, plug the PSP into the AC adapter like you would to charge it, turn it on, and if all goes well put the battery back in. Wait about 10 minutes with all plugged in then unplug the charger. If the PSP turns off then it is a battery issue. If it wont turn on even with the AC adapter plugged in it is an adapter issue
you can also try:
Press & hold the following buttons @ the same time:
Select->Start->Square->Triangle->POWER
Puntuación 0
1 comentario:
Dont Understand what you mean by take the battery out and plug back in
- de
To unbrick a PSP hold all 5: HOME+SELECT+START+SQUARE+TRIANGLE and then POWER IT UP.
Sony start-up screen should appear in about 3-5s.
Puntuación 0
Same thing was my battery had to take it out working without it just needs charging
Puntuación 0
I took the battery pack out and I had the ac adapter plugged in the whole time the green light came on for a second and then turned off. And it was on a black screen the entire time.
Puntuación 0
I had this issue today and I did like the short show button and home and then the power button it’s worked for once and now it doesn’t work anymore. Can somebody help me?
Puntuación 0
Añadir tu respuesta
Tomasz Videos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 105
Todo El Tiempo: 25,644
